undead11
Newbie level 2
- Joined
- Sep 2, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 24
Hi friends,
I synthesize a very simple veirlog code but I got an following error when I did "synthesize -to_mapped". There is nothing between the single quotes. How can I find what and where the error is? I will list my code and tcl file. BTW, I used RTL Compiler. Thanks.
Error : A required object parameter could not be found. [TUI-61] [get_attribute]
: An object named '' could not be found.
: Check to make sure that the object exists and is of the correct type. The 'what_is' command can be used to determine the type of an object.
Usage: get_attribute <string> [<object>+]
<string>:
attribute name
[<object>+]:
object of interest (must be unique)
-----------------------verilog code--------------------------------------
module test1
clk,
rst,
x_in,
y_in,
x_out
input clk,rst;
input [15:0] x_in, y_in;
output [15:0] x_out;
reg [15:0] x_out;
wire flag;
assign flag = x_in[15];
always @(posedge clk or negedge rst)
if (~rst)
x_out<='d0;
else
begin
if (flag)
x_out<=x_in+y_in;
else
x_out<=x_in-y_in;
end
endmodule
----------------------------tcl-----------------------------------------------------------------------
set_attribute lib_search_path {/users/bh/class/CPE411/STD/Synopsys}
set_attribute library {/users/bh/class/CPE411/STD/Synopsys/smic13_ff_1p32v_0c.lib}
read_hdl -v2001 {/users/bh/class/CPE411/syn1/source/test1.v}
set target_technology smic13_ff_1p32v_0c
elaborate
check_design
read_sdc -stop_on_errors /users/bh8/class/CPE411/syn1/script/timing.sdc
<string>:
attribute name
[<object>+]:
module test1
clk,
rst,
x_in,
y_in,
x_out
input clk,rst;
reg [15:0] x_out;
wire flag;
if (~rst)
x_out<='d0;
else
begin
if (flag)
x_out<=x_in+y_in;
else
x_out<=x_in-y_in;
end
endmodule
elaborate
check_design
