hfc1993911hfc
Newbie level 6
- Joined
- Jan 24, 2014
- Messages
- 14
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 11
- Activity points
- 98
I am trying to design a boost converter to drive an LED by using LM3478. The input voltage is not a certain value but a voltage range(6V~ 17V). The ouput voltage is about 40V. During power inductor selection ,the datasheet of LM3478 says the average inductor current should be larger than the inductor current ripple. so we can esaily get a expression :
L>D(1-D)*Vin/(2*Iout*fs),
So the duty cylce(D) should be known first.
Of course, If i want to calculate the duty cycle, a formula[Vout=Vin/(1-D) ] will be used. and here is my puzzle:
1. when i calculate the duty cycle, what value should i use for Vin, 6V or 17V ,or some value else ?
2.when i use the epression of "L>D(1-D)*Vin/(2*Iout*fs)" to calculate the inductor value, should use the value of Vin the same as above ???
