The best way to assign a fixed LOW to an input of a module?
wanida
fixed low inputs
Hello.
Just need some confirmation.
What is the best way to assign a fixed LOW to an input of a module?
I want to instantiate a module into my design with inputs that I want to fix as LOW, do I need to declare a new internal wire signal and declare the width, and assign it to LOW?
Or is it perfectly all right for me to assign the value '0' in the module instantiation?
e.g. (.inputname(0)).
Thanks.
fixed low inputs
You can simply use e.g. (.inputname(0)) this approach if you want to make u r inputs either tied to high/low.
Re: fixed low inputs
dcreddy, thanks.
When I did Analysis and Elaboration, I got this warning that says the mentioned signal is connected to a 32 bit bus whereas my signal is a single bit, and the irrelevant bits are ignored.
Is that a waste of connections or is it ok and considered better than declaring a new internal signal wire?
fixed low inputs
You can explicitly tell :
parameter bit_width = 1; // Change according to your bit width
(.inputname({bit_width{1'b0}}))
    wanida
