.TF equivalent in cadence...
bharatsmile2007
Full Member level 3
Hi All
In HSPICE .TF finds the ratio of small-signal input resistance to the small-signal output resistance.
How to find out the same through cadence?
xf simulation
try: cdnshelp &
MMSIM 6.21
Products
spectre
Manuals, search for:
xf
7. Transfer Function Analysis (xf)
HTH! erikl
bharatsmile2007 said:
Hi All
I am not familiar with HSPICE (but with many other simulation packages) - however, are you sure that .TF is really Rin/Rout ?? And what are you interested in ??
I suppose, .TF rather will be the small signal transfer function Vout/Vin.
Hi erikl and LvW
Thanks for ur reply's...
I wanted to find out the output impedance of BGR(Bandgap Reference Voltage) design.Can you pls let me know how to find the output impedance of BGR in cadence?
Pls find the schematic of BGR attached....
Thanks a ton... :)
Hi erikl and LvW
Thanks a ton... :)
In each simulation program the output impedance of a circuit can be found by feeding a current (ac source) into the output and measure the voltage created across the output.
Hi LvW,
thanks for the reply...
I will connect a acm of 1Amp at the output node,perform ac simulation and find the voltage at the output node.so the Zout is the voltage at the node itself.
Am i correct? Pls correct if iam wrong....
Yes, this will work, too, (as in xf simulation), s. sim. plot below:
Thanks erikl..
Added after 5 hours 2 minutes:
Would you pls explain me the advantages and disadvantages of the below circuit?
