tetra max questions
Does anyone know if there is a way to run loops (repeat commands) in tetramax or from a command file? For example if I want to repeat a series of commands N times? (I could just copy and paste but N here may be a very large number.)
Also, I am trying to figure out the number of faults detected by a few different vectors which I'm reading in from a file, (for each vector), however due to fault dropping I have to keep resetting the fault list between fault simulations. Is there a way to get around this? (I'm using the full scan method and apparently the nodrop fault option only works for sequential simulation, why is that and is there a way around it?)
Please let me know if anyone has any ideas, thanks.
