isidrobu
Newbie level 1
Hi, I'm new to programming system c. The following code describes a RAM module where we can write and read, simulating a ram. What I have to do is a test (testbench). A test that I thought is put into memory number, and then print to see that the memory is working properly. I have looked in several places as testing but I did not teach me anything good.
A greeting.
#include <systemc.h>
#define MEM_SIZE 512
SC_MODULE(Memory) {
public:
enum Function {
FUNC_NONE,
FUNC_READ,
FUNC_WRITE
enum RETSignal {
RSIG_NONE,
RSIG_READ_FIN,
RSIG_WRITE_FIN,
RSIG_ERROR
sc_in<bool> Port_CLK;
sc_in<Function> Port_Func;
sc_in<int> Port_Addr;
sc_inout<int> Port_Data;
sc_out<RETSignal> Port_DoneSig;
SC_CTOR(Memory) {
SC_METHOD(execute);
// sensitive_neg(Port_CLK);
m_clkCnt = 0;
m_curAddr = 0;
m_curData = 0;
m_curFunc = Memory::FUNC_NONE;
m_data = new int[MEM_SIZE];
m_writesCnt = 0;
m_readsCnt = 0;
m_errorsCnt = 0;
m_errorCode = 0;
~Memory() {
delete [] m_data;
private:
int m_clkCnt;
int m_curAddr;
int m_curData;
Function m_curFunc;
int* m_data;
int m_errorCode;
int m_writesCnt;
int m_readsCnt;
int m_errorsCnt;
RETSignal myread() {
if(m_errorCode == 0) {
Port_Data.write(m_data[m_curAddr]);
m_readsCnt++;
return RSIG_READ_FIN;
} else {
m_errorsCnt++;
return RSIG_ERROR;
RETSignal mywrite() {
m_data[m_curAddr] = m_curData;
m_writesCnt++;
return RSIG_WRITE_FIN;
} else {
m_errorsCnt++;
return RSIG_ERROR;
void execute() {
if(m_curFunc != Memory::FUNC_NONE) {
m_clkCnt++;
if(m_clkCnt == 100) {
RETSignal retSig = Memory::RSIG_ERROR;
switch(m_curFunc) {
case Memory::FUNC_READ : { retSig = myread(); break; }
case Memory::FUNC_WRITE : { retSig = mywrite(); break; }
Port_DoneSig.write(retSig);
m_clkCnt = 0;
return;
if(Port_Func.read() == Memory::FUNC_NONE) {
return;
m_curFunc = Port_Func.read();
m_curAddr = Port_Addr.read();
m_curData = Port_Data.read();
Port_DoneSig.write(Memory::RSIG_NONE);
SC_MODULE(CPU) {
public:
sc_in<Memory::RETSignal> Port_MemDone;
sc_out<Memory::Function> Port_MemFunc;
sc_out<int> Port_MemAddr;
sc_inout<int> Port_MemData;
SC_CTOR(CPU) {
SC_METHOD(execCycle);
sensitive_pos(Port_CLK);
dont_initialize();
SC_METHOD(memDone);
sensitive(Port_MemDone);
dont_initialize();
m_waitMem = false;
private:
bool m_waitMem;
Memory::Function getrndfunc() {
int rndnum=(rand() % 10);
if(rndnum < 5)
return Memory::FUNC_READ;
else
return Memory::FUNC_WRITE;
int getRndAddress() {
return (rand() % MEM_SIZE);
int getRndData() {
return rand();
void execCycle() {
if(m_waitMem) {
return;
int addr = getRndAddress();
Memory::Function f = getrndfunc();
Port_MemFunc.write(f);
Port_MemAddr.write(addr);
if(f == Memory::FUNC_WRITE)
Port_MemData.write(getRndData());
m_waitMem = true;
void memDone() {
if(Port_MemDone.read() == Memory::RSIG_NONE) {
return;
m_waitMem = false;
Port_MemFunc.write(Memory::FUNC_NONE);
int sc_main(int argc, char* argv[])
cout << "\n\nCreating Modules............";
/* Instantiate Modules */
Memory mem("main_memory");
CPU cpu("cpu");
/* Signals */
sc_signal<Memory::Function> sigMemFunc;
sc_signal<Memory::RETSignal> sigMemDone;
sc_signal<int> sigMemAddr;
sc_signal<int> sigMemData;
/* The clock that will drive the CPU and Memory*/
sc_clock clk;
cout << "DONE\nConnecting Modules' Ports...";
/* Connecting module ports with signals */
mem.Port_Func(sigMemFunc);
mem.Port_Addr(sigMemAddr);
mem.Port_Data(sigMemData);
mem.Port_DoneSig(sigMemDone);
cpu.Port_MemFunc(sigMemFunc);
cpu.Port_MemAddr(sigMemAddr);
cpu.Port_MemData(sigMemData);
cpu.Port_MemDone(sigMemDone);
mem.Port_CLK(clk);
cpu.Port_CLK(clk);
sc_start();
cout << "DONE\n" << endl
<< "\n\nRunning (press CTRL+C to exit)... ";
system("pause");
return 0;
A greeting.
SC_MODULE(Memory) {
public:
enum Function {
FUNC_NONE,
FUNC_READ,
FUNC_WRITE
enum RETSignal {
RSIG_NONE,
RSIG_READ_FIN,
RSIG_WRITE_FIN,
RSIG_ERROR
SC_CTOR(Memory) {
SC_METHOD(execute);
m_clkCnt = 0;
m_curAddr = 0;
m_curData = 0;
m_writesCnt = 0;
m_readsCnt = 0;
m_errorsCnt = 0;
m_errorCode = 0;
~Memory() {
delete [] m_data;
private:
int m_clkCnt;
int m_curAddr;
int m_curData;
Function m_curFunc;
int* m_data;
int m_errorCode;
int m_writesCnt;
int m_readsCnt;
int m_errorsCnt;
m_readsCnt++;
} else {
m_errorsCnt++;
return RSIG_ERROR;
m_writesCnt++;
} else {
m_errorsCnt++;
return RSIG_ERROR;
void execute() {
m_clkCnt++;
switch(m_curFunc) {
m_clkCnt = 0;
return;
return;
SC_MODULE(CPU) {
public:
SC_CTOR(CPU) {
dont_initialize();
SC_METHOD(memDone);
dont_initialize();
m_waitMem = false;
private:
bool m_waitMem;
if(rndnum < 5)
else
int getRndData() {
return rand();
void execCycle() {
if(m_waitMem) {
return;
m_waitMem = true;
void memDone() {
return;
m_waitMem = false;
CPU cpu("cpu");
/* Signals */
sc_clock clk;
mem.Port_CLK(clk);
cpu.Port_CLK(clk);
sc_start();
system("pause");
return 0;
