walters
Advanced Member level 2
when building a Test fixture that has multiple pins sticking up to test for test points and vias
What are the best pins to use?
Because the pins are causing intermittent problems because they aren't thick enough to be touching the copper through hole plating, or the plating is not that great on the PCB boards that are made
What can I do to fix this problem please?
