flote21
Advanced Member level 1
- Joined
- Jan 22, 2014
- Messages
- 411
- Helped
- 1
- Reputation
- 2
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 5,595
Hello,
I have a question about the 33ohm terminator resistors. According to the datasheet of this clock driver:
"A minimum number of external components are required for proper operation. A decoupling capacitor of 0.01 µF should be connected between VDD on pin 1 and GND on pin 4, as close to the device as possible. A 33 Ω series terminating resistor may be used on each clock output if the trace is longer than 1 inch.
To achieve the low output skew that the ICS553 is capable of, careful attention must be paid to board layout. Essentially, all four outputs must have identical terminations, identical loads and identical trace geometries. If they do not, the output skew will be degraded. For example, using a 30Ω series termination on one output (with 33Ω on the others) will cause at least 15 ps of skew."
I am using this driver for clocking 4 ADCs. Then I don't know where I have to place the 33ohm resistors, close to the clk pin of the ADC or close to the output pins of the clock driver?
On the other hand if I route the tracks to the 4 ADCS with the same lenght, Should be neccessary to put also the 33ohm resistors?
Thanks.
Thanks.
