avr terminal
I was actually intrested to practice my C programming with out downoading to target. For this purpose I tried Proteus (Very bad experience) it looks that every module in it have bug. I tested 6.3 SP1 and 6.2 Sp5.
The main thing was there was no Mega128 simulation module so I use Mega103 and compile my programes for it.
I used CodeVision-AVR 1.24 for compilation.
UART buffer function does not work on the Mega128 module. So I tried AVR Studio 4 but it does not have Terminal Simulation may be new one have......
I finally tried BascomAVR-11174. A little trick is needed to simulate the code that not generated by BascomAVR.
NON BASCOMAVR SOURCE CODE SIMULATION AT BASCOMAVR SIMULATOR
Give the same name to the basic file in BascomAVR as the other compiler and the both compiler files (source and generated) should be in the same directory. Confuger the BascomAVR for the BAUD AND CHIP, Compile the few dummy line of BascomAVR then compile your real program in other compiler (in my case CVAVR) and then run the sumulation in BascomAVR. Please note that the BascomAVR use OBJ file and search for ASM file so your real compiler should be able to generate these files.
DO NOT TRUST ON PROTEUS I REALY HAVE BAD EXPERIENCE
Good Luck :lol:
