100k
Member level 1
- Joined
- Jun 16, 2012
- Messages
- 37
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,607
Hi
I bought this Tenma 72 7730 digital multimeter from element14. After sometime its continuity function stopped working, I do not know the reason. I could not figure out what happened. I checked its fuses(2 fuses), replaced batteries but it did not worked.
I complained about this to element14 and requested for replacement but they did not took this issue seriously. I contacted the technical support of mcmelectronics also, they suggested that it might be something wrong inside the multimeter and suggested for replacement.
Over the time when it was kept useless, it regained its continuity function. I could not figure out neither the cause of this problem nor the reason how it regained its ability.
It worked fine for many months but it again lost its continuity function.
Can anyone explain me what went wrong with this multimeter and how to fix this.
PS: I have checked its fuses and batteries again, there is no damage to them. There is no physical damage visible through visible inspection.
