evilguy
Full Member level 4
as we know in SPICE there is command for setting the simulation temperature. and the command is:
.TEMP
actually how this command affect the simulation? that this command is similar when we varies TNOM in SPICE parameter? for example if we set
and do dc operation point analysis, did we will get the same result when we do the same simulation with TNOM set to 30?
thank you.
.TEMP
.TEMP 30
thank you.
