chandrasekaran
Newbie level 1
Hi al,
For the past 2 days i am trying to read the value from temperature sensor ds18b20.But i didnt get the any values.i have few doubts.Actually i am connecting ds18b20 with renesas controller(r8/tiny series).
Normally in renesas controller if a pin is made as input.we need to enable pullups.
My doubt is..
In the sensor pdf, they have mentioned to connect pullup for DQ pin(data pin).So i connected 4.7k to VCC.But is it necessary to use both the pullups(internal pullup of controller+DQ pin pullup)?
Also in sensor pdf they mentioned about time delays for reading the values as well as writing the values..I am not giving delays less than what they have mentioned.But i have given delay more than that..Suppose if they have mentioned to give 1usec delay means i had given 10 usecs.Will it cause any problem?
My doubt is..
