[SOLVED] Telit GM862-Gps stuck when receiving a call
dxtr
Member level 3
Member level 3
hey everybody
i'm working on Telit GM862-GPS
i already write some scripts in order to be familliare with it , the problem is when the script is running and i call the telit , it shows me RING RING in the terminal , the script stops completly.
i understand that calls are considred like interrupts , but why after ending the call he don't continue running the script ?
and how i can disable calling the module ?
thnx for the help
Its okey guys i resolve it , the trick is so simple when receiving a call the MDM buffer has the string "RING" instead of what it should normally have
