clayt
Newbie level 5
- Joined
- Jan 31, 2013
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Canberra, Australia
- Activity points
- 1,372
I see two uses for Generics in a VHDL entity:
1. To provide a Name to an otherwise magic number, but where the value is never intended to be changed.
2. A Parameter that allows the entity function to be changed from instance to instance.
Eg:
Here the entity is a 16 bit multiplier. WIDTH is intended to be used to define the width of the interface, but it is not intended to be changed. It is a 'fixed value'. Allowing it to change may make implementation difficult, or would require testing at different widths or whatever.
'WIDTH' is just used to put a Name to what would otherwise be '16' (a potentially meaningless value).
and:
Here the intention is that DATA_WIDTH can be changed to any values as required for each instance. It is a 'parameter'.
What I am trying to determine is how to enforce or encourage users to make a distinction between these two uses, and ensure that 'fixed value' generics don't get changed. Maybe there is a convention of a name prefix or suffix that can indicate one or other. Of course comments can indicate the usage. An ASSERT would also be another way to ensure a fixed value does not get changed.
Any ideas? Are there any standard conventions for such things?
Clayton
Canberra, Australia
Eg:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 entity Multiply16Bit is generic ( WIDTH : integer := 16 ); port ( clk_in : in std_logic; a_in : in std_logic_vector ( (WIDTH - 1) downto 0) := (others => '0'); b_in : in std_logic_vector ( (WIDTH - 1) downto 0) := (others => '0'); mult_out : out std_logic_vector ( (WIDTH - 1) downto 0) := (others => '0') ); end Multiply16Bit;
and:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 entity Delay_1 is generic ( --! Data width parameter DATA_WIDTH : integer := 16 ); port ( --! Clock input clk_in : in std_logic; --! Data Input data_in : in std_logic_vector((DATA_WIDTH - 1) downto 0); --! Data Output data_out : out std_logic_vector((DATA_WIDTH - 1) downto 0) ); end Delay_1;
Clayton
Canberra, Australia
