htg said:How can I excite only the TE10 mode in most of the waveguide?
htg said:The point is that I think about using balanced input to a dipole, which I want to place in the waveguide. What about such a solution?
htg said:It looks like things are significantly frequency-dependent here.
volker_muehlhaus said:You dipole idea makes no sense to me. The coax to waveguide probe linked above will create the proper mode much better than your "dipole in a box".
htg said:Why would the center pin of a coax work better than a dipole?
htg said:How long should the protruding center pin of the coax be?
