TCL proc to generate : variable nb of lists which contain a variable nb of elem
pierre13
Junior Member level 3
Hello,
I would like to implement in Tcl a procedure which generates the following element lists (example with 4 lists) :
list1_1 list2_1 list3_1 list4_1
list1_1 list2_1 list3_1 list4_2
list1_1 list2_1 list3_1 list4_3
list1_1 list2_1 list3_2 list4_1
list1_1 list2_1 list3_2 list4_2
list1_1 list2_1 list3_2 list4_3
list1_1 list2_2 list3_1 list4_1
list1_1 list2_2 list3_1 list4_2
list1_1 list2_2 list3_1 list4_3
list1_1 list2_2 list3_2 list4_1
list1_1 list2_2 list3_2 list4_2
list1_1 list2_2 list3_2 list4_3
list1_1 list2_3 list3_1 list4_1
list1_1 list2_3 list3_1 list4_2
list1_1 list2_3 list3_1 list4_3
list1_1 list2_3 list3_2 list4_1
list1_1 list2_3 list3_2 list4_2
list1_1 list2_3 list3_2 list4_3
list1_1 list2_4 list3_1 list4_1
list1_1 list2_4 list3_1 list4_2
list1_1 list2_4 list3_1 list4_3
list1_1 list2_4 list3_2 list4_1
list1_1 list2_4 list3_2 list4_2
list1_1 list2_4 list3_2 list4_3
list1_2 list2_1 list3_1 list4_1
list1_2 list2_1 list3_1 list4_2
list1_2 list2_1 list3_1 list4_3
list1_2 list2_1 list3_2 list4_1
list1_2 list2_1 list3_2 list4_2
list1_2 list2_1 list3_2 list4_3
list1_2 list2_2 list3_1 list4_1
list1_2 list2_2 list3_1 list4_2
list1_3 list2_4 list3_1 list4_2
list1_3 list2_4 list3_1 list4_3
list1_3 list2_4 list3_2 list4_1
list1_3 list2_4 list3_2 list4_2
list1_3 list2_4 list3_2 list4_3
However, the difficulty comes from the fact that the number of lists is variable, and the number of the elements of each list is also variable.
Example :
set list_1 "list1_1 list1_2 list1_3"
set list_2 "list2_1 list2_2 list2_3 list2_4"
set list_3 "list3_1 list3_2"
set list_4 "list4_1 list4_2 list4_3"
list1_1 is the first element of the list_1 and so on.
I have already made the following procedure but it works only for a fixed number of lists. I would like to implement a procedure for a variable number of lists which contains a variable numbe rof elements.
proc generation_foreach {} {
global list_1 list_2 list_3 list_4
set number_combi 0
foreach element_list_1 $list_1 {
foreach element_list_2 $list_2 {
foreach element_list_3 $list_3 {
foreach element_list_4 $list_4 {
puts "$element_list_1 $element_list_2 $element_list_3 $element_list_4"
return 0
Can someone help me ?
Thanking advanced.
Pierre
