TC429 mosfet driver configuration doubt
renga92
Member level 5
Member level 5
india
I am planning to use TC429 MOSFET driver to drive BUZ330. I am using a 10khz signal pwm signal from the micro controller to vary the voltage using MOSFET. Will this mosfet driver drive signals at 10khz. I checked the data sheet but it is of no use.
thanks in advance
10KHz should be no problem for those parts. The TC429 datasheet shows the rise/fall times, which are <100ns.
