Target slack unconstrained after synthesis
kannanunni
Member level 1
Member level 1
Trivandrum, Kerala
What is the reason for showing "Target slack unconstrained" after synthesis???
and there also shows no generated clock found for "report clocks -generated" command in RC?
rc:/> report clocks -generated
Generated by: Encounter(R) RTL Compiler v09.10-p104_1
Generated on: Jan 25 2011 12:01:28 PM
Module: soc_top
Technology library: NangateOpenCellLibrary revision 1.0
Operating conditions: typical (balanced_tree)
Wireload mode: enclosed
Area mode: timing library
No clocks to report
but i given a clock constraint like this..
rc:/> report clocks
Generated on: Jan 25 2011 12:02:19 PM
Module: soc_top
Clock Description
Clock Clock Source No of
Name Period Rise Fall Domain Pin/Port Registers
clk 10000.0 0.0 5000.0 domain_1 0
Clock Network Latency / Setup Uncertainty
Network Network Source Source Setup Setup
Clock Latency Latency Latency Latency Uncertainity Uncertainity
Name Rise Fall Rise Fall Rise Fall
clk 0.0 0.0 0.0 0.0 0.0 0.0
Clock Relationship (with uncertainity & latency)
From To R->R R->F F->R F->F
clk clk 10000.0 5000.0 5000.0 10000.0
Please do reply..
report_clocks -generated is empty cause you have no generated clocks defined.. have you?
You have a clock named "clk" defined which reflects; target slack unconstrained is may be cause your not reporting the correct endpoints or there is no timing path for the path you wish to report.
how should i define generated clock?
and actually this target slack unconstrained shows in the initial optimization phase. so what's the reason?
pls go through the SDC reference once anyways the command is :create_generated_clock
I am not sure when you say initial phase of optimization .. pls push the snippet of the log
ok that's solved..
now i have another problem..
Error : Unable to map design without a tristate buffer or inverter. [MAP-1] [synthesize]
: The design is 'minsoc_top'.
: Check the libraries for necessary tristate cell. The cell could be marked unusable.
so
how to find tristate inverter from timing lib???
It says that the lib is marked unusable i.e. set_dont_use
Basically all tri-state inverter libcells are marked false so it should be easy to find in the lib.
Try playing with the "find" command
