dirac16
Member level 5
I have been working on a recent paper. Basically I want to re-do the simulation results provided in the article. The circuit is a type of Wilkinson power divider with wide passband and stopband, and a also wide isolated frequency band. The circuit with its parameters is shown below.
Basically I want to re-draw the layout as shown above and do a post layout simulation. The substrate is Rogers RO4003C with the dielectric constant 3.55, loss tangent 0.0027, and layer thickness 0.813mm. First for the microstrip coupler lines I have to find the associated width (W), length (L), and separation (S) using Linecalc tool. I did this for the middle coupler and found the following physical lengths (@f0=2.4GHz):
W4=4.19mm (as compared with W4=3.96mm)
L4=4.52mm (L4=4.07mm)
S4=0.71mm (g2=0.44mm)
As you see my calculated lengths are slightly bigger than those illustrated for the middle coupler in the bottom right table. This is clear because Linecalc did not take into account the electric fringes which causes the transmission line to have a slightly shorter effective length. Now how can I find the physical lengths by considering the electric fringes effect? Is there a clear way to find the effective lengths?
Thanks
Thanks
