Re: Matlab to FPGA
hi rsrinivas & echo,
Thanks for the solution both u guys providing.. it really helps..
the VHDL code which generate from matlab is synthesizable by ALTERA quartus 2, however, it has more than 512 warning of the Fann in problem for just a minimal 4th order FIR equiripple low pass filter
and the total LE usage is 21% of FLEX 10K which i dont know is efficiency or not...
do you guys know how to design a FIR filter manually by just designing a simple FIR block diagram and manually convert into VHDL programming then download to the target device and run it..
i wonder wat outcome it would be, and the problem we facing?
thanks
and wish to hear for you guys soon
