synthesis result functional error
quake
Member level 5
Member level 5
hi, what usually cause the functional error of the sythesized netlist? I mean the most common reason, like clock, reset or even pads can cause this problem? any others? thanks
jackson_peng
Full Member level 2
Full Member level 2
Shanghai, China
glitch, especially on your generated clock or reset
metastablity, data exchange between different clock domain.
Nandy
Full Member level 1
San Jose CA
Synthesis tool can bring some functional errors in netlist. For example, DC ultra can translate some logic into wrong gates. You better use logic equivalent check tool to make sure RTL==netlist.
Like Jackson said, glitch can make RTL sim different with netlist sim
Nandy
www.nandigits.com
Netlist Debug/ECO in GUI mode.
anjali
Full Member level 3
Full Member level 3
async logic should be taken care while synthesis.
quake
Member level 5
Member level 5
thank you so much. Then the question becomes: what steps are usually done
to find out where the problem is ? since it is so hard to trace those signals in a netlist, any special routines to do it?
xworld2008
Full Member level 4
Full Member level 4
I think you can use formal tools to check you netlist , which can find different between netlist and rtl code.
Nandy
Full Member level 1
San Jose CA
Nandigits provides a good netlist debug tool, GOF.
It's very powerful in isolating failing logic in formality check.
For example, starting from one failing cell, using mouse to click on the cell's input pins or output pins, a circuit is drawn. And it makes thing simple for you to check what's wrong in the logic.
Take a look at following link
https://www.nandigits.com/p40.htm
GOF is free for none-commercial usage.
Nandy
www.nandigits.com
