manasic
Junior Member level 1
- Joined
- Nov 2, 2013
- Messages
- 15
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 3
- Activity points
- 154
Hello All;
I have code which compare two address(which is a std_logic_vector). I have written it in a pacakge named distance with the function named as path_cost. The code is in vhdl and synthesis tool is synopsys 2011.
Below is the code and synthesis error.
synthesis error:
Loading vhdl files: '/net/grads/mchoudha/vhdl/mroots-routing/distance.vhd' '/net/grads/mchoudha/vhdl/mroots-routing/router.vhd'
Running PRESTO HDLC
Compiling Package Declaration DISTANCE
Compiling Package Body DISTANCE
Compiling Entity Declaration ROUTER
Compiling Architecture BEHAVIOR of ROUTER
Warning: /net/grads/vhdl/mroots-routing/router.vhd:18: The architecture behavior has already been analyzed. It is being replaced. (VHD-4)
Warning: /net/grads/vhdl/mroots-routing/router.vhd:27: The initial value for signal 'node_database' is not supported for synthesis. Presto ignores it. (ELAB-130)
Warning: /net/grads/vhdl/mroots-routing/router.vhd:59: 'node_database[0]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Error: /net/grads/vhdl/mroots-routing/distance.vhd:35: Constant value required. (ELAB-922)
*** Presto compilation terminated with 1 errors. ***
Error: Can't read 'vhdl' files '/net/grads/vhdl/mroots-routing/distance.vhd', '/net/grads/mchoudha/vhdl/mroots-routing/router.vhd'. (UID-9)
No designs were read
design_vision>
the code highlighted is giving error. I tried to look for online on this and found that , if loop cannot have a variable value. I am nota ble to change it to fixed values beacuse design needs to flexible. Can anyone suggest a work around. I am waiting for the answer. Will be really great if anyone can help.
Manasi
package body distance is
-- purpose: calculate the path cost (distance) between node1 and node2
-- example: address1 = "234", address2 = "235";
-- example: closest common ancestor = "230", remainder1 = "4", remainder2 = "5", remainder_width = 1
function path_cost (
constant address1 : std_logic_vector (8 downto 0);
constant address2 : std_logic_vector (8 downto 0))
return integer is
variable digit_pointer : integer := 3; --the iterator of octal digits
variable ancestor_identified : boolean := false;
-- a flag: initialized as false, set to true as soon as the common ancester is identified
variable remainder_width : integer := 0;
variable node_distance : integer := 0; -- the distance of node1 and node2
begin -- path_cost
--stage1: find closest common ancestor
while (ancestor_identified = false and digit_pointer /= 0) loop
[B] if address1 ((digit_pointer*3-1) downto ((digit_pointer-1)*3)) = address2 ((digit_pointer*3-1) downto ((digit_pointer-1)*3)) then[/B]
digit_pointer := digit_pointer - 1; --ancestor unidentified, keep searching
else
ancestor_identified := true;
end if;
end loop; --now digit_pointer = remainder_width
remainder_width := digit_pointer;
synthesis error:
Running PRESTO HDLC
design_vision>
Manasi
