Syntax Problem with compiler
I
imroun1992
Newbie level 1
Hello,
I had already post a thread about I2C Communication & LM75 Thermometer .. After several time, I wrote a program which is used to read temperature :
#include <LPC43xx.h>
#include "LED.h"
#include "KBD.h"
#include "GLCD.h"
#include "I2C.h"
#include "TH_LM75.h"
#include <stdio.h>
#include <math.h>
#include <stdlib.h>
#define Font1       1
#define Font0       0
#define STRINGBUF_LEN   21
char StringBuf[STRINGBUF_LEN];
/*** Prototypes des fonctions ***/
void configuration_lm75(char);
int  acquisition_temperature(void);
void DisplayTemp(void);
/*** Fonction principal ***/
int main(void)
    I2C_Init();
    TH_Init();
		GLCD_Init();
		GLCD_Clear (White);
    GLCD_SetBackColor  (Blue);
    GLCD_SetTextColor  (White);
    GLCD_DisplayString (0, 0, 1, "    Project      ");
    GLCD_DisplayString (1, 0, 1, "  Electronics    ");
    GLCD_SetBackColor  (White);
    GLCD_SetTextColor  (Blue);
    while(1)
						configuration_lm75(0x00);
						DisplayTemp();
						configuration_lm75(0x01);
/* Ecriture des données dans le registre de configuration du LM75 */
void configuration_lm75(char data)
    I2C_Start();
    I2C_Write(0x90);        // Slave address + Write
    I2C_Write(0x01);        // Configuration register address
    I2C_Write(data);        // Data to register
    I2C_Stop();
/* Lecture de la température */
    int data;
		TH_DATA Temp;
    signed char high, low;
    I2C_Start();
    I2C_Write(0x00);        // Temperature register address
    I2C_Start();
    I2C_Write(0x90|0x01);   // Slave address + Read
		TH_GetTemp(&Temp);
    I2C_Stop();
    data = high;
    data *= 10;
    if(low & 0x80)
        data += 5;
    return data;
    int temp;
    temp = acquisition_temperature();    // Leer temperatura
    sprintf("\r\n Temp = %d.%d C",&temp/10, abs(temp%10));
In the void function DisplayTemp(void) at last line "sprintf...", there is a mistake i don't know what is it, anyone to help me Compiler said :
argument of type "int" is incompatible with parameter of type "const char *restrict"
Anyone to help I include with this post the LCD Screen source files
Kind regards
  • mcb4300v1-3-schematics.pdf
  • source files.zip
  • LCD_source_files.zip
I presume you cannot perform the division operation directly over a pointer variable.
Try replace these 2 lines for aimplementation bellow :
    temp = ( acquisition_temperature() ) /10;    // Leer temperatura
    sprintf("\r\n Temp = %d.%d C",&temp, abs(temp%10));
Hello,
There is same problem, your code not working. compiler said same things
I don´t know what compiler are you using, but are you sure can use pointer variable ?
I presue correct way is the following :
sprintf("\r\n Temp = %d.%d C",temp, abs(temp%10));   ////// removed '&' statement before temp variable
your code is not working i have the same message, can you see the source file named "TH_LM75 that i had included with this thread
Code C - [expand]
int sprintf(char *str, const char *format, ...)
https://www.tutorialspoint.com/c_standard_library/c_function_sprintf.htm
Code C - [expand]
8
9
10
11
unsigned char strTemp[8];
strTemp[0] = temp / 100 + 48;
strTemp[1] = (temp / 10) % 10 + 48;
strTemp[2] = (temp % 10) + 48;
strTemp[3] = '.'
strTemp[4] = abs(temp % 10) + 48;
strTemp[5] = '\0';
sprintf("\r\n Temp = %s C", strTemp);
Also try
Code C - [expand]
unsigned char myString[20];
sprintf(myString, "\r\n Temp = %d.%d C", temp, abs(temp%10));
Hello,
i attached uvision project files
  • uvision project_thermometer_proj.zip
doesnt sprintf needs a buffer to save de string? i would try sprintf (buffer,"message",variables);
Which file contains the sprintf() function?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
#pragma hdrstop
#pragma argsused
#include <stdio.h>
#include <tchar.h>
#include <math.h>
#include <string.h>
int _tmain(int argc, _TCHAR* argv[])
    int temp;
    char myString[20];
    temp = 2456;
    sprintf(myString, "Temp = %d.%d C", temp, abs(temp%10));
    printf("myString contains %s", myString);
    scanf("%d", &temp);
    return 0;
  • sprintf.rar
Hello,
I don't know but i would like to display temperature in LCD screen, can you check the program if all I2C syntax are correct please,
I think sprintf is belong to #include <stdio.h>
