Synopsys Tools - Problems with openSUSE 12.2 32-b
jgnr
Junior Member level 1
Hello everybody,
I'm doubt about wich files i need to use in installing vcs tool at openSuse12.2 32b.
Do I need to install the common.tar and (linux.tar or suse32.tar)?
I've installed the suse32.tar but now when I'm executing the vcs in command line the terminal gives this message:
# vcs -f vcs_script.scr
ERROR - /home/synopsys/vcs/linux/bin is not valid directory, is VCS_HOME set correctly?
 Perhaps vcs hasn't been installed for machine of type "linux".
 Or the installation has been damaged.
 To verify whether vcsG-2012.09 supports machine of type "Linux 3.4.6-2.10-desktop",
 please look at ReleaseNotes for more details .
 We determine the machine type from uname; maybe uname is incorrect.
 You can fix installation problems by reinstalling from CDROM
 or downloading it from the Synopsys ftp server.
 For assistance, please contact vcs technical support
 at vcs_support@synopsys.com or call 1-800-VERILOG
I considered that openSUSE was bashrc shell so i set the tool's variables in .bashrc as in centOS, but for some reason the system is not running the tool, same occured with ic_shell, dc_shell and pt_shell.
If someone have some help on configuring the tools in openSUSE, i'll be greatful.
