Hi ,
I have reset synchroniser module in my design.
The asynchronous reset coming from top level is synchronised on different clocks generated internally. From that modules various resets flow to other modules of the design.
I have declared reset signal in the scan command file by the follwing command
set_dft_signal -type Reset -port extRstn.
If I connect the top level asynchronous reset to all the logic, then we are getting full coverage, instead if I connect that synchronous resets, the coverage results are bad. I have the following queries :
(1) whether to keep the clkRst module for the scan synthesis ?
(2) Is it correct to connect Synchronous resets to the modules ,if yes how to declare ?
Thanks in Advance
Downloadman
