Synchronous Generator Internal ABC Stator Voltages from DQ
digi001
Full Member level 5
Hello.
I am using a Synchronous Generator Model in Matlab which gives me Internal Stator Voltages (not the terminal voltages) in DQ0 form. However I would like to also view these in ABC form.
If I use the inverse Clark/Park DQ0 block to transformer back to abc, what do I use for the theta Angle?
I am using the Rotor Angle for this, but this seems to not be working correctly (i think)?
Help!?
the position of the motor
