yonglim
Newbie level 3
Hi everyone,
I designed a synchronous buck converter with the zero current detector (ZCD) to have a option to select between CCM/DCM at light load condition. The control method is traditional voltage mode PWM and no pulse skipping/PFM in DCM mode.
At first, I thought the efficiency is always better in DCM mode during light load but surprisingly in my simulation the efficiency in CCM mode is actually better than DCM mode. The way I measure the efficiency is have a fix load at the output and let the converter run for a long time, after the converter reach steady state I take the average of the input current flow into the converter.
When I compare the input current waveform between CCM/DCM mode, there is a reverse current flow back to the input source in CCM mode when the high side FET turned on, since the inductor current is negative, while in DCM mode the input current always flow into the converter.
Now, if I take the average of the input current for both CCM/DCM mode, the average input current in CCM mode is actually less than the average input current in DCM mode, which results in the efficiency in CCM mode is better than DCM mode.
People always implement pulse skipping/PFM mode in DCM but I think this is not a fair comparison, I am interested in the efficiency comparison between two mode under the same voltage mode PWM control.
Someone said I should take rms current instead of average current, I think this is not correct because if you take rms current no way the converter can reach 90% efficiency number.
I hope anyone who experienced in switching converter design can join this thread to discuss or answer my doubt.
