Syn0psys library c0mpiler error
xirix
Full Member level 2
Romania
I have in a synopsys library a primitive with logic function:
"(!A&!C) | (B&C) | (A&!B)"
Library compiler (ver.2000...2003) does not recognize the function and give the error:
"Failed to recognize the functionality of cell....(LIBG-10)"
DC will not use such function as it is marked as removable.
Does anybody tell me what is wrong with this 3-input function?
Thanks
edacrack
Member level 3
Because if you make the truth table, that logic function will be true no matter what the value of A, B, C so the compiler doesn't need to compile this circuit
xirix
Full Member level 2
Romania
From truth table, for C=1, A=B=0,
Y=(!A&!C) | (B&C) | (A&!B) = (1&0) | (1&0) | (0&1)=0
The rest of the values are 1 logic.
So, this isn't a constant function.
I'm wondering if we could blaim syn0psys parser.
xirix
Full Member level 2
Romania
Still no suggestion?
cnspy
Full Member level 3
You can take one of a, b, c as a select signal of the other two. then it seams like a AND / OR.
DC will work on this express well.
xirix
Full Member level 2
Romania
I tried already the other forms:
"C ? (A|B) : !(A&B)" or "(A|B)&C | !(A&B)&!C" with the same result.
