galenthas
Newbie level 3
- Joined
- Jan 28, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 39
Hello all,
Through my frustrations and heading back here over and over again for references and suggestions today I'm posting my first thread here in need of desperate help.
I had a similar problem with costas loop before. I then scratched my head against the walls (i know i am not that bright) and learned the theory nehind the loop filter and vco and stuff and implemented a model with system generator that operates @ 300 MHz and capable of tracking b-q-8-psk signals. I know its no big deal.
So i thought i could implement the timing recovery now with some work, but I couldn't. I have studied the papers, simulink models, reference hdl codes.
Ok, i am trying to implement the timing recovery circuit with gardner ted. I have the blocks all ready; gardner ted, loop filter, vco and all that but when put together they simply don't work. I even tried direct conversion of the matlab simulink demo to vhdl but i am missing something.
My gardner ted samples twice the symbol rate and outputs the correspoing error. I have my loop filter parameters (which i believe is not the cause of my problem). I implemented the vco with good sensitivity and correct center frequency.
Do you have any suggestions for me? Should i do more reading? Or did you have such experience?
Regards.
Regards.
