for example i have 10 data blocks
and took 5 symbols in in data block
and then i measured avg power for each data block in awgn. then at receiver side i plotted avg received power vs ber
I've never seen this before zunayeed, but if you want to check your code, plot the conventional BER vs. SNR and it would roughly be 10^-5 at 10 dB SNR. Good luck
