udir
Newbie level 5
- Joined
- Dec 28, 2012
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,383
Hi Friends,
I have a problem that I would like you to address.
I have an analog board which produces a 1 Mhz signal (close to sine wave).I used a Mosfet push pull terminology using a 24v DC input to generate this signal by switching the DC input using these Fets over a planar transformer.
The problem is that one of the Mosfets (or both) are burning out (you can clearly see that high currents burnt it or it became so hot that the tin welding it to the PCB has reached its boiling point and caused it to bend!) when the AC to dc power supply which delivers the 24 vdc to the switching transistors is fed by 110V AC/60 HZ (and according to spec it suppose to withstand it with no problem as it multi power supply by meanwell).
Whats strange is that when the same AC to dc power supply is fed by 220VAC/50HZ there is no problem what so ever.....which puzzles me...
The same cooling fan operates on these 2 Mosftes in both cases, so I just can get it,,,,
any advise?
any advise?
