ayashisunyday
Newbie level 3
- Joined
- Jun 18, 2013
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 33
Gentlemen,
I'm working on a small PCB that will be made with SMTs. Due to the components caracteristics (most of them will fry with only a few miliAmp) I'm trying to evaluate the good ones to pick and the correct design to stay green.
I've assessed everything except the current that will flow between my transistor C/E pins when the switch is closed.
Basically this transistor is used to ground C1 and clear it. The circuit is a peak & hold detector.
I've attached the design (board is powed in 0 / +5V):
The transistor is a MMBT2222AWT1G. The datasheet says "Collector Current − Continuous, ICmax = 600mAdc" does that means that it can handles up to 600mA ? Simulation says that the current can reach 33mA.
Thanks for your help!
Aya.
Aya.
