switching scheme of mosfet full bridge inverter
maxim10373
Full Member level 1
Dear friends
please clear the confusion about the working of mosfet full bridge
(six switch)inverter, which switches(mosfet) will work the forward
and reverse direction of motor controller..
regards
maxim
Not sure if this is what you are asking about:
Four switching devices will do it, as long as your control signal can both sink and source current, and as long as it reaches a sufficiently high volt level in order to turn off the P-devices.
Screenshot:
Hi Maxim
The circut is as given below It can Go forward and reverse
As I understand that it is a three-phase inverter.
To reverse the motor signals to the phases A and C are interchanged
Thanks. But, I know the switching strategy of single phase
inverter.Its confused three phase inverter High and Low side.
