switching four devices using a PRESET
niteshtripathi
Member level 3
Member level 3
I have a switch board consisting 4 switches, as we know well are four switches are independent, means we can either switch ON or OFF desired switch.
I want to switch ON/OFF these four devices independently means at a time any no of switches can be switched ON or OFF by using a single preset. so for that i am using a ADC which convert the analog o/p from preset in digital which is fed to MCU(AT89S52). but the prob is that when i want to switch ON or OFF one device then the status of other devices get changed.
#include<reg52.h>
#define cmdport P3
#define dataport P2
#define adc_input P1
sbit rs = cmdport^2;
sbit rw = cmdport^1;
sbit e  = cmdport^0;
sbit wr= cmdport^4;
sbit rd= cmdport^3;
sbit intr= cmdport^5;
sbit relay1=P0^0;
sbit relay2=P0^1;
sbit relay3=P0^2;
sbit relay4=P0^3;
unsigned char i,a,d1,d2,d3,d4,x1,x2,x3,x4,b,c,d,z[4];
unsigned char text[]= "SW1:OFF SW2:OFF ";
unsigned char text1[]= "SW3:OFF SW4:OFF ";
unsigned char text2[]= "ON ";
unsigned char text3[]= "OFF";
unsigned char i,a,b,c,d,input;
void delay(unsigned int msec)
int i,j ;
for(i=0;i<msec;i++)
for(j=0;j<1275;j++);
void lcdcmd(unsigned char item)
dataport = item;
rs= 0;
rw=0;
e=1;
delay(1);
e=0;
void lcddata(unsigned char item)
dataport = item;
rs= 1;
rw=0;
e=1;
delay(1);
e=0;
void convert(unsigned int value)
	x1 = value / 10;
	d1 = value % 10;
	x2 = x1 / 10;
	d2 = x1 % 10;
	x3 = x2 / 10;
	d3 = x2 % 10;
	d4 = x3 % 10;
	d1=d1|0x30;
	d2=d2|0x30;
	d3=d3|0x30;
	d4=d4|0x30;
	lcddata(d4);
	lcddata(d3);
	lcddata(d2);
	lcddata(d1);
void main(void)
adc_input=0xff;
relay1=0;
relay2=0;
relay3=0;
relay4=0;
delay(50);
lcdcmd(0x38);
delay(100);
lcdcmd(0x0E);
delay(100);
lcdcmd(0x01);
delay(100);
lcdcmd(0x06);
delay(100);
lcdcmd(0x80);
delay(100);
for(i=0;i<=15;i++)
lcddata(text[i]);
delay(1);
lcdcmd(0xc0);
delay(1);
for(i=0;i<=15;i++)
lcddata(text1[i]);
delay(1);
lcdcmd(0x80);
while(1)
				for(i=0;i<3;i++)
                delay(1);
                rd=1;
                wr=0;
                delay(1);
                wr=1;
                while(intr==1);
                rd=0;
                lcdcmd(0x88);
                input=adc_input;
                delay(1);
                intr=1;
                z[i]=input;
				z[3]=(z[0]+z[1]+z[2])/3;
				input=z[3];
				lcdcmd(0x01);
				lcdcmd(0x80);
				convert(z[2]);
				if(input>20&&input<50)
				  delay(100);
				  if(a==0)
				  relay1=1;
				  a=1;
				  lcdcmd(0x84);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text2[i]);
				  delay(1);
				  else
				  relay1=0;
				  a=0;
				  lcdcmd(0x84);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text3[i]);
				  delay(1);
				  delay(200);
			     else if(input>70&&input<95)
				  delay(100);
				  if(b==0)
				  relay2=1;
				  b=1;
				  lcdcmd(0x8C);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text2[i]);
				  delay(1);
				  else
				  relay2=0;
				  b=0;
				  lcdcmd(0x8C);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text3[i]);
				  delay(1);
				  delay(200);
			     else if(input>100&&input<120)
				  delay(100);
				  if(c==0)
				  relay3=1;
				  c=1;
				  lcdcmd(0xc4);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text2[i]);
				  delay(1);
				  else
				  relay3=0;
				  c=0;
				  lcdcmd(0xc4);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text3[i]);
				  delay(1);
				  delay(200);
			     else if(input>120)
				  delay(100);
				  if(d==0)
				  relay4=1;
				  d=1;
				  lcdcmd(0xCC);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text2[i]);
				  delay(1);
				  else
				  relay4=0;
				  d=0;
				  lcdcmd(0xCC);
				  delay(1);
				  for(i=0;i<=2;i++)
                  lcddata(text3[i]);
				  delay(1);
				  delay(200);
