hello
I want to design a circuit that is capable of switching between several shunt resistors to have periodic check of values for each of them.
This idea came to our mind, when we found that the dedicated power ics usually have limited analog channels, and we want to multiplex several shunts.
another problem, is that the minimum current that we want to measure in each shunt is about 1 mA, and this cause in shunt around 10 uv .
We thought in analog multiplexers, but I doubt that they can transmit this AC 10 uV without distorting them. we thought about amplifying the output from shunt using opamp so the analog multiplexer can deal with it, but again, I did not find suitable opamp that can amplify 10 uv with acceptable uncertainty (many opamps measure less than 10uv, but the datasheet mentions that this value can be up to 30uv ), and reasonable price.
are there any suggestions ?
