jumanji
Newbie level 6
- Joined
- Mar 15, 2011
- Messages
- 13
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,395
I have a simple mcu-based circuit board that turns on and off 12V mechanical relays. The board requires 12V DC to operate which goes through a 5V regulator to the mcu and the rest of the circuit. There are 10uF tantalum caps on both the 12V signal coming into regulator and the 5V DC going out. The relays are turned on and off using a ULN2003 driver which has a diode built in to prevent back emf when the relay is turned on and off. When there is no load connected to the relays I don't have any problems. However, when I have an AC or DC load of some kind routed through the relay, I see significant spikes on the 5V DC signal on my board. I am confused as to why this is happening - my assumption was that the load on the relay was essentially isolated from the circuit that is driving the relay and it that it didn't really make any difference what the load on the relay was. Can anyone enlighten me as to what is going on?
