The smallest one comercially available is only ca. 5x 2x 2.5mmIanP said:...may have to consider the use of reed relays – some of them are in DIL-housing...IanP
That's right ..conanhaha said:If I get a relay that got diode suppression coil mean that i do not need to add the diode IN4148 like attach on picture above?
With pin [K=9] connected to Vcc - that's right too ..conanhaha said:By the way, when connect to ULN2003/ULN2803, I do not need to add in the diode also?
