purifier
Full Member level 4
Can someone help me with the following:
1. What are switch mode power supplies and how are they used ?
2. How can they be used to charge a Lead-Acid Battery? say 12 V , 30 Amp Hours .
3. What are the requirements of the battery?what does the battery need? Is the batteries temperature a factor?
4. What circuits would you use to charge the battery?What current is usual to charge the battery?
5. How would you build a charger for such a battery using a switch mode power supply?
I would be pleased if someone could answer the above questions... Please help...
