neazoi
Advanced Member level 6
Hi, I have a cheap inverter that is connected to a 24v battery and produces 220V AC.
I would like a circuit (or a cheap product) that will detect if the battery has a low voltage (I will have to set this threshold) and automatically switch the output to the AC mains instead of the inverter output.
Ie. when the battery is not charged, the inverter is bypassed and the output is connected to the AC mains instead of the AC output of the inverter.
The problem is, that I need the AC output not to be interrupted during the switching process. This can be done with a make-before break relay, but the problem is that I do not know if the inverter allows 220V to be present on it's output. By using this relay, the instant time the MAKE connection is done, 220v mains are connected to the inverter output.
Any schematics or cheap commercial products that can do this?
