Switch connected to 74hc589
djc
Advanced Member level 1
India
Hi all,
I have connected 8 switches to 8 parallel inputs of 74hc589. I want to get the status of 8 switches. Here is my code
void clock_function()
//                     par_rck = 1;
//                     #asm("nop")
//                     par_rck = 0;
                     par_sload = 0;
                     #asm("nop")
                     par_sload = 1;
                                        if(par_out==1){
                                        key_status[7]=1;
                                        else{
                                        relay_44=0;
                                        par_sck = 1;              //G   Q7
                                        #asm("nop")
                                        par_sck = 0;
                                        if(par_out==1){
                                        key_status[6]=1;
                                        else{
                                        relay_33=1;
                                        par_sck = 1;                //E  Q6
                                        #asm("nop")
                                        par_sck = 0;
                                        if(par_out==1){
                                        key_status[5]=1;
                                        else{
                                        relay_22=1;
                                        par_sck = 1;               // E  Q5
                                        #asm("nop")
                                        par_sck = 0;
                                        if(par_out==1){
                                        key_status[4]=1;
                                        else{
                                        relay_11=1;
                                        par_sck = 1;                //E  Q4
                                        #asm("nop")
                                        par_sck = 0;
                                        if(par_out==1){
                                        key_status[4]=1;
                                        else{
                                        key_4++;
                                        if(key_4==200){
                                        key_status_44=1;
                                        //relay_44=1;
                                        if(key_4==400){
                                        key_status_44=0;
                                        //relay_44=0;
                                        key_4=0;
                                        par_sck = 1;                //D  Q3
                                        #asm("nop")
                                        par_sck = 0;
                                        if(par_out==1){
                                        key_status[5]=1;
                                        else{
                                        key_3++;
                                        if(key_3==200){
                                        key_status_33=1;
                                        //relay_33=1;
                                        if(key_3==400){
                                        key_status_33=0;
                                        //relay_33=0;
                                        key_3=0;
                                        par_sck = 1;                //C    Q2
                                        #asm("nop")
                                        par_sck = 0;
                                        if(par_out==1){
                                        key_status[6]=1;
                                        else{
                                        key_2++;
                                        if(key_2==200){
                                        key_status_22=1;
                                        //relay_22=1;
                                        if(key_2==400){
                                        key_status_22=0;
                                        //relay_22=0;
                                        key_2=0;
                                        par_sck = 1;                 //B   Q1
                                        #asm("nop")
                                        par_sck = 0;
                                        if(par_out==1){
                                        key_status[7]=1;
                                        else {
                                         key_1++;
                                        if(key_1==200){
                                        key_status_11=1;
                                        relay_11=1;
                                        if(key_1==400){
                                        key_status_11=0;
                                        relay_11=0;
                                        key_1=0;
                                        par_sck = 1;                  //A   Q0
                                        #asm("nop");
                                        par_sck = 0;
Here i am looking for counter key_1 to key_4 to compete the count of 200 to change the switch variable status to 1 and count of 400 to change the switch variable status to '0'. But instead of  incrementing the variable i want it to change the status at once. Means if switch is pressed once corresponding variable status should  change. How to do that, please guide.
