Rosalinekavitha
Member level 1
i have designed a circular spiral coil using equation based curve in HFSS. while sweeping along path if the circle radius is 0.1mm the coil sweeps correctly. but when the circle radius is increased to 0.2mm, curve get diminishes leaving circle alone. how to fix this issue?
Is there any proportionality relation between inner radius of coil and wire radius in HFSS?
In general, inner diameter of coil is measured form center to center of inner wound or merely the space at the center?
