boopy
Newbie level 2
We are running a simulation to model transmission through an odd shaped object that we drew in HFSS. We want to put a square wave port on a rounded side of it but can't figure out how do that. Since that failed we put a wave port on one end of the object. The port crosses over multiple objects but are contained inside of another larger cylinder. We have the port on the end of the larger cylinder right now but we are getting errors. The "sweep/setup/model does not converge" error. We are trying to use adaptive sweep and frequency interpolating sweep and have been having no luck. We're going 10Hz to 10GHz. We unchecked the lambda refinement... delta s is set to 0.02 but increasing it didn't make any difference. We're using a wave port.
