Sw Regulator VS linear regulator
wisepie
Member level 4
Why nowday people prefer sw regulator rather than linear regulator?
well the varying of output voltage is easy and also output of different polarity and higher than input are possible....
Presume you mean Switch Mode Reg. Much more efficient, less heat. Bad stuff, greater EMI and more complex to build. Latter option not really an issue so much as chip solutions are available. Needs very careful design of SM if used with sensitive measuring/medical equipment etc. Great for general purpose use, and as Anand says also.
Also Switch mode regulator may be buck, boost and buck-boost (inverting).
The problem of sw power circuit is mainly for audio circuits.
Hence otherwise sw circuits r nice as already discussed above.
Switch mode power supply:
pros:
- high efficiency,
- easy to create and adjust the wide range of output voltage/current.
- light weight.
cons:
- big noise/interference. Not suitable for analog circuits if lack of other measures.
- output voltage is not really clean, lots of spikes, hums, ... with a large frequency range.
- hard to build, repair.
- expensive.
Linear power supply:
pros:
- output voltage/current are very clean. This is very suitable for analog circuit.
- easy to build, easy to adjust, easy to repair.
- low noise/interference.
- cheap.
cons:
- heavy.
- low efficiency.
- not easy to change the output voltage/current.
As you see, nowadays, digital electronics become very popular, so this is the era for the switch mode power supply. jaya000 is right, for example, analog audio system is now still the best over the digital, you cannot find out any switch mode power supply in the high quality audio system but still see the big heavy transformer there.
nguyennam
SW regulator can generate isolated voltage output, but LDO cannot
I do not think this is true in general. There are situations where the sw regualtor is preferred and other where the linear regulator is preferred.
factors:
power consumption
regulation
accuracy
and switch mode outperforms linear in these regards.
