supply voltage monitor
franticEB
Full Member level 3
Full Member level 3
Hi all,
I would like to design a circuit to monitor the supply voltage of a board.
Suppose that is 50Volts, I wish I had reported variations of + / -5% of the latter.
The circuit for reading shold be composed by the microcontroller + AD connected trough spi interface and feed by dcdc converter for various voltage
(50Volts --->|||--->3,5,15volts).
Important that monitor circuit and power supply are isolated between them.
Could you help me with some ideas,schematics and with the research of components to be used?
thanks
When you want isolation, an optocoupler is a common technique.
The internal LED lights up in proportion to current through it. The internal photosensor reacts by changing its resistance accordingly.
To obtain expanded scale measurement, put a zener diode in series with your source. Then the LED will show greater variations in brightness, as the supply voltage changes. This should allow you to detect + or - 5% variation.
Example:
So how could i measure this variation by AD converter or by microcontroller? Is it so sensitive? Could you explain me better your idea?
Here is a more complete schematic:
The output level (at right) will drop with an increase in the applied volt level (at left). Your sense software must invert this behavior.
The optocoupler will give a roughly linear response to the applied volt level. Your sense software will need to account for this. You'll have to experiment with resistor values, to obtain the best operating range. At no time should you expose the devices to overmuch current.
Some more information at:
https://www.electronics-tutorials.ws/blog/optocoupler.html
https://www.technogumbo.com/projects/Learning-to-Use-an-Optocoupler-or-OptoIsolator/
