A superheterodyne receiver basically in corporates LNA, BPF filters to perform Band selection operation, Image Rejection operation and Channel selection operation. It also in corporates two stages of downconversion mixer hence resulting in the name of hetero(different) and dyne(mix).Superheterodyne receiver has superior image and adjacent channel rejection capabilities, with a tradeoff of high power dissapation compared to its counterpart of homodyne receiver
Transceiver processes and sends the RF signals, while receiver catchs and processes the RF signals, almost in inverse sequence than the first one.
Supeheterodine system is the same in both (works in the same maner).
You may read a book about RF electronics (like RF microelectronics by Razavi).
Superhetrodyne receiver translates the RF to so-called IF by the first mixer to perform filtering and amplification. So the filter at RF and IF is refered to as Channel select filter and Image reject filter, which bring good performance. Then, the IF signal is downconverted to the baseband by the second mixer.
Compare to the homodyne, hetrodyne has no DC offset problem, much less flicker noise impact, but more complicated design and image problem.
For wideband wireless communications, such as ieee802.11a, both the research and the industry area all tend to use directconversion receiver.
the concepts can be caught easily. the TI application note has detailed description. how to decide the parameter value of every level is difficult.
I found nothing from google, can anyone tell me where I can find papers?
THANKS
