clip
Newbie level 2
The cv2880 is a cost-effective and high performance sensor image signal and video signal processor
for high-end digital/analog display application.
CV2880 built-in 1080P Scaler, full-screen OSD, 10bit DAC, TV Encoder, 64M Memory and RAM Controller,support all digit signal input and most of digit and analog signal output, basic application include Industrial Camera/vidicon,Visual Presenter, Security and protechtion monitoring, Video conversion, Especial industrial application etc.
Input Formats:
1.5M(2596x1944) pixel CMOS sensor bayer (RAW Data) input
2.8bitBT656
3.8bit/16bit BT601
4.8bit/16bit BT1120
5.8bit/16bit YC422
6.24bit YUV444/RGB444
7.16/24/32bit TTL
8.Supports SD and HD, interlaced scan and progressive scan, Operation up to 165 MHz.
9.Auto Mode detection.
Output Format:
1.8bit BT656
2.8bit/16bit BT601
3.8bit/16bit BT1120
4.8bit/16bit YC422
5.24bit RGB444/YUV444
6.16/24/32bit TTL
7.Composite video(cvbs and s-video)
8.Analog VGA output.
9.Analog YPbPr output.
10.CVBS and S-Video output together.
11.CVBS and S-Video support PAL and NTSC system.
12.VGA up to 1920x1080@60 or 2560x1440@30.
13.YPbPr up to 1080P60
Intelligent Image Processing:
Black and white level expansion
Flesh Tone Correction
Horizontal Peaking
Digital Luminance Transient Improvement
Digital Chroma Transient Improvement
ACCE(Adaptive Color & Contrast Enhancement)
Gamma correction
AE/AF/AWB for sensor bayer input
Vertical flip/horizontal mirror
Deinterlacing
Edge Correction and Motion-adaptive SDTV (NTSC/PAL) / HDTV(1080i) deinterlacing
Film mode support for 3:2 and 2:2 pull-down
Advanced 2D and 3D Noise Reduction for cross-color suppression
Scaling
Fully programmable zoom ratios
Independent Horizontal/vertical scaling
Advanced zoom algorithm provides high image quality
On-chip OSD controller
On-chip RAM for high-quality programmable menus
1,2,and 4-bit per pixel character cells
Programmable character cells size
Horizontal and vertical stretch of OSD menus
Blinking, transparency and blending
Packaging
1.8V/3.3V, Typical power consumption is 280MA
Built-in ESD/TVS, up to 8000V.
Operating temperature range: -40 to 110(Centigrade)
80PIN LQFP-0.5.
Dimension:12mm x 12mm.
Some basic applicions inclue: AV TO HDMI, HDMI TO AV, BT656 TO VGA/HDMI, BT1120 TO VGA/HDMI, HDMI TO BT1120, AHD TO CVBS/VGA/YPBPR/HDMI, TVI TO CVBS/VGA/YPBPR/HDMI , RAW RGB TO VGA/CVBS etc.
Pls visit our website: www.chipav.com or mail to sales@chipav.com if you need further infomation.
Input Formats:
2.8bitBT656
3.8bit/16bit BT601
4.8bit/16bit BT1120
5.8bit/16bit YC422
7.16/24/32bit TTL
Output Format:
1.8bit BT656
2.8bit/16bit BT601
3.8bit/16bit BT1120
4.8bit/16bit YC422
6.16/24/32bit TTL
Horizontal Peaking
Gamma correction
Deinterlacing
Scaling
Packaging
80PIN LQFP-0.5.
