alexxx
Triac input=230V@50Hz. The load is a a flyback converter and will draw max 90mA@230V or 150mA@150V.
150mA inductive load means I need at least 1.5A RMS on-state current right? Also from what I read sensitive gate is better, but if I use a non sensitive triac and add a resistor 1K between G and T1, I'm OK. And also if I use a 4q triac (instead of a 3q), I need to use an RC snubber.
Are those correct conclusions? Are there any other aspects I should take into account? The drive circuit is from MOC3023 optotriac datasheet.
