FPGA suggestions
Hi all,
I've been making my first foray into the world of logic design.
As a first project, I've designed a very simple 4-bit CPU in about 150 lines of Verilog. I simulated it and it works fine. My question is: Where do I go from here?
I know that Xilinx and Altera are the major FPGA makers. I would probably want to use an FPGA (for later expandability). What kind of synthesiser software would I need to get? I tried Icarus Verilog's "xnf" and "fpga" outputs, but they were plagued by internal errors. Presumably I would need something from Xilinx or Altera; what kind of expense am I looking at?
And where do you get the FPGAs to begin with? I've seen **broken link removed**, but it might be overkill. If you just get the FPGA (no dev board), how complex is it to plug into a circuit?
I'm definitely a newbie at this stuff; thanks for any help you might have.
-- Josh
