Suggestions on good high power RF Switch
khouly
Advanced Member level 5
EGYPT
high Power RF Switch
hi all
i want to design or buy high power RF Switch , the 1 dB compression point is about 37 dBm
any recommendations ?
thanks in advance
khouly
Re: high Power RF Switch
Hello,
any idea of frequency range and switching speed? I assume the power spec is CW and impedanc is 50 Ω?
Frank
    khouly
Hi
You do not do not mention the required frequency, isolation, insertion loss or speed of the switch, but I can recommend switches from Hittite.
I have used the HMC544 which is a GaAs PHEMT. Depending on control voltage it can have an 1-dB compression point of 39 dBm.
But check out the datasheet: https://www.hittite.com/index.cfm?b...ction&source=leftnav&subID=107,143&subHead=18
Regards
    khouly
Hello Khouly,
Narda Microwaves are providing high power switches.Go through www.nardamicrowave.com
As per designing your own switch is concerned, have a look at this document.Hope this will help you........
    khouly
thanks all
the frequnecy from 100 MhZ , to 2 GHz
the switching speed is not an issue ,
khouly
