Re: Colour LCD
Hello!
brucelee2 said:
Hi Bobi,
Thanks for the reply. Ok im getting it now. RAM is important. I can imagine its hard to find drivers for some colour LCD controllers and its a horrid task to write one.
Just for your info, here is an article my boss just wrote (but I did the demo).
It is linked to a video showing what can be done with a moderate power
microcontroller (MSP430F5438). (See following URL).
This doesn't have a lot of memory (16 k), but in fact I access the data using
512-byte buffers (in order to access the SD card). The filesystem can be run
on a 2k bytes RAM system (for instance it works with a F169 chip), so I guess
you wouldn't need more for that kind of application.
Even if you use more than 4 colors, you can write nice menus (using pixmaps
for their background, that you can edit using any PC), you can make menus that
are quite reactive. It takes around one second to write a page of 63 icons in this
demonstration. So if you use always the same pixmap as a background (i.e. if
you don't have to read it everytime from the SD card), it becomes a lot quicker.
I will try to make another demo one of these days, using only one background
for all the menu tiles. I'm sure it will be extremely fast.
Dora.
